Hegel H190 Integrated Amp/DAC/Streamer - SOLD
0 Members and 1 Guest are viewing this topic. Read 676 times.
Phil A
« on: 2 Aug 2021, 11:30 pm »
SOLD
Asking $2,900, including shipping to the continental US and Paypal
Used very sparingly in a secondary system. Acquired in September 2018. I had a power amp, preamp, DAC and music server in that secondary systembut didn't use the system much so I sold those and acquired the Hegel H190 which simplified the system. I broke the amp in and after that it has seen less than 10 hours of use in the 3 years since I've owned it (I have multiple secondary systems). Also have a Synergistic Blue Fuse available for it for a reasonable additional amount. Asking price includes shipping and paypal to the continental US.
Technical Specifications
Power output: 2 x 150 W into 8 Ω
Minimum load: 2 Ω
Analog Inputs: 1 x balanced (XLR), 2 x unbalanced (RCA)
Digital Inputs: 1 x coaxial (BNC), 1 x coaxial (RCA), 3 x optical, 1 x USB, 1 x Network
Line level Output: 1 x unbalanced fixed (RCA), 1 x unbalanced variable (RCA)
Frequency response: 5 Hz - 100 kHz
Signal-to-noise ratio: More than 100 dB
Crosstalk: Less than -100 dB
Distortion: Less than 0.01% @ 25 W/8 Ω/1 kHz
Intermodulation: Less than 0.01% (19 kHz + 20 kHz)
Damping factor: More than 4000 (main power output stage)
Dimensions incl feet: 12 cm x 43 cm x 41 cm (HxWxD), 19 kg shipping weight
Dimensions (US): 4.72" x 16.93" x 16.15" (HxWxD), 41.89 lbs shipping weight
A review can be found here - https://www.lbtechreviews.com/test/hi-fi/hegel-h190
« Last Edit: 4 Aug 2021, 03:13 am by Phil A »
