introduction and troubleshooting the encore xl
0 Members and 1 Guest are viewing this topic. Read 726 times.
cfanderson66
« on: 1 Aug 2021, 09:58 pm »
Hello,
First time here. I just finished building the encores, however only the woofers work - nothing coming through the tweeters. I checked for continuity and everything seems to book. anyone have this experience? Thanks
richidoo
Re: introduction and troubleshooting the encore xl
« Reply #1 on: 1 Aug 2021, 10:50 pm »
Welcome to AudioCircle!
Make sure tweeters are not shorted to ground. That causes mute.
Tool for testing correct XO wiring before 1st flight: DATS
Hobbsmeerkat
« Reply #2 on: 1 Aug 2021, 11:05 pm »
Welcome to AC!
I would double check the crossover network for the tweeter, its possible that something was wired incorrectly. It sounds to me like that if the continuity is ok, you might have the resistors positions mixed up, or have too many in the signal path.
Post a picture of your crossover (with the values hidden) and im sure we can walk you thru the process.  :thumb:
EdwardT
« Reply #3 on: 2 Aug 2021, 02:23 pm »
You should hear audio from a good tweeter even if it’s wired incorrectly as long as the lead is attached somewhere in the positive side of the circuit. Maybe this visual guide will help:
