*SOLD* MC Phono stage *SOLD*
0 Members and 1 Guest are viewing this topic. Read 812 times.
undertow
« on: 31 Jul 2021, 08:46 pm »
*SOLD*
Custom built component for a dealer about 4 years ago. As seen in photos this is a "Half Shelf" component around 12" wide, 4" high, 13" deep weight 10 lbs.
Unit is SILVER. Unit is in perfect physical and working condition.
- The DEAL // you can audition this unit and return, however you are responsible for shipping cost back.
$625.00
Price drop to $550.00
PAYMENT will be ZELLE, VENMO, or PAYPAL F/F with no fees.
Price includes shipping to 48 states U.S. via FED EX Home or Ground. [/size][/color]
This unit features -
- Toroid power transformer running the linear balanced power supply for main phono.
- Separate transformer, and linear power supply completely independent of above main power supply feeding the KAB Subsonic filter.
[Kab subsonic filter was provided by Kab 100% transparent to the circuit and makes sure your woofers do not pump]
- Isolation of power supplies with Nu-Metal barrier allowing this unit to have zero internal noise or hum.
- IEC power input your choice of power cable
- Cardas RCA Input and output jacks
- Entire unit is wired in KIMBER KABLE internal solid core wiring made for high end components.
- Hifi Tuning Silver Star main fuse
- Front power LED / REAR power switch to turn unit on and off.
- 60 db standard gain for / MC - with standard 100 ohm loading.
If you have any MC cartridge from .2 mV up to .6 mV and requires the standard 100 ohm load this is a perfect unit. No switches, no noise, full linear power supplies with all dead silent audio grade components. Simple and musical.
« Last Edit: 2 Sep 2021, 03:07 pm by undertow »
undertow
48 state shipping included.
undertow
« Last Edit: 13 Aug 2021, 05:39 pm by undertow »
undertow
$550.00
Shipped
undertow
