Speaker standa
0 Members and 1 Guest are viewing this topic. Read 1562 times.
Ragnar71
Speaker standa
« on: 29 Jul 2021, 02:22 am »
Does anyone know of any good speaker stands to recommend?
jjss49
Re: Speaker standa
« Reply #1 on: 29 Jul 2021, 04:41 am »
target
sound anchor
skylan
tontrager
Re: Speaker standa
« Reply #2 on: 29 Jul 2021, 10:28 am »
Timber Nation.  They provide sturdy stands at reasonable prices and you can customize.  It does take weeks for manufacturing and delivery.
Customizing is huge.  Size to fit your monitor, can oversize the base for better stability, and get the height to match your ear height from your listening position.
« Last Edit: 29 Jul 2021, 03:29 pm by JLM »
poseidonsvoice
    • 2 channel/7 channel setup
Re: Speaker standa
« Reply #3 on: 29 Jul 2021, 10:48 am »
Jeff Dicks makes nice stuff:
https://www.standmanstands.com/standman-stands.html
Best,
Anand.
Big Red Machine
Re: Speaker standa
« Reply #4 on: 29 Jul 2021, 12:04 pm »
I was quite impressed with the steel stands from MonoPrice.
owlsalum1
Re: Speaker standa
« Reply #5 on: 29 Jul 2021, 07:10 pm »
I use Sound Anchor stands that are actually intended for Harbeth C7 monitors with my Salk SoundScape 7M monitors. Rock of Gibralter stable for my 7Ms (which are heavy and on the large side for monitors). The best part is Acoustic Sounds typically stocks Sound Anchor stands in a range of sizes for Harbeths and you can have the best stand I know of in-house quickly. That's what I did - purchased from Acoustic Sounds.
