FS: Rega RP3, TTPSU, Groovetracer Counterweight, and other accessories
0 Members and 1 Guest are viewing this topic. Read 963 times.
Rischa
It's time to pass along my well cared-for Rega RP3 & TTPSU. The RP3 was purchased new in 2012, the TTPSU a year or two later.
The RP3 has a couple upgrades. The arm was professionally rewired by Britaudio in 2018 using Cardas Pure Copper Litz wire with Cardas solid brass gold plated cartridge clips, and the original steel platter bearing was upgraded to a Groovetracer zirconia bearing.
I don't have the original felt dust mat, but it will come with a never-used after-market white felt mat.
Also included:
--Groovetracer under-hung counterweight (but the original Rega counterweight is there, too)
--3-point tonearm spacer in case you want to use a non-rega cart, with 2, 4, 6, and 8mm heights.
--Almost new (less than 100 hours) Rega white belt upgrade
--BRAND NEW, never used replacement dust cover hinges
--1 bottle lubricant
--Comes with all original packaging and manuals.
A couple notes about condition:
The tonearm lift only stays up for a second or two before the tonearm starts to slowly fall. I've read this is normal for older Rega decks and it still works fine for cueing records, so it's never bothered me.
Also, the dustcover has some light scuffing, but couldn't get it to photograph.
The plinth is essentially flawless.
Would like to get $800 for the whole package.
Sorry, local pick-up only near Madison, WI.
Rischa
I also have a Rega tungsten counterweight I can throw in with the sale. That's $320 in counterweights, not including the RB303 counterweight.
djbnh
Best of luck with your sale. Regarding the arm lift drop, the following is from the Rega circle in The Vinyl Engine forum:
Rischa
Many thanks for the tip!
