Copying files from pc to bdp3
0 Members and 1 Guest are viewing this topic. Read 846 times.
Rush2112
« on: 22 Jul 2021, 04:09 pm »
Bought a 2tb internal ssd for the bdp3 . First hooked up the ssd in an adapter connected to the pc and copied some of my cd's onto the ssd . Then installed the ssd into the bdp3 . Worked fine . No problems . Now want to copy more of my cd's onto this internal ssd in the bdp3 . Worse case scenario would be to take the ssd back out of the bdp3 and copy the rest of my cd's to the ssd drive . Trying to figure out how to transfer more of my cd's to this internal ssd without removing it .  I am running a windows 10 pro desktop pc . In file explorer i do not have anything when i search for bdp-3 . Any help would be appreciated . Thanks Darrell
Francois_Tardif
Re: Copying files from pc to bdp3
« Reply #1 on: 22 Jul 2021, 06:45 pm »
Before anything, if it's not already done, do this modification to your Windows settings:
https://support.wdc.com/knowledgebase/answer.aspx?ID=20736
Rush2112
« Reply #2 on: 22 Jul 2021, 07:12 pm »
Have done that mod in windows 10 . Windows features and checked off smb1.0 . What do i need to do next ? Thanks Darrell
Rush2112
« Reply #3 on: 22 Jul 2021, 07:33 pm »
Got it figured out . Thank you very much for your help . Darrell
Francois_Tardif
« Reply #4 on: 22 Jul 2021, 07:34 pm »
Now, enjoy this wonderful unit! :-)
François
gbaby
« Reply #5 on: 22 Jul 2021, 07:55 pm »
Actually, I think its better to use 4 512 gig USB drives rather than a hard drive that may crash.  :o
Francois_Tardif
« Reply #6 on: 22 Jul 2021, 08:04 pm »
... or a NAS system with  2 (or more) hard drives that are arranged into RAID.
