FS: Rogue Audio Apollo "Dark" Monoblocks
0 Members and 1 Guest are viewing this topic. Read 898 times.
Avinash
« on: 19 Jul 2021, 06:19 am »
Rogue Audio Apollo "Dark", this is the latest Flagship amp from Rogue Audio. Each monoblock has 6 x KT120, 2 x 12AU7, 1 x 12AX7. Can be used in TRIODE or ULTRA-LINEAR mode. You can adjust bias on each individual tube, more accurate than other amps where you adjust for a group of tubes. I have the original box, but not willing to ship. This will have to be an in person deal. I'm in Phoenix, AZ.
From Rogue Audio website:
General Features:
- Monoblock design for perfect channel separation
- Massive high storage LC power supply
- Ultra-high performance transformers
- Built in bias meters and bias tool
- All precision components
- 6 x KT120, 2 x 12AU7, 1 x 12AX7 tubes per amplifier
- CNC machined aluminum chassis
- Heavy-duty gold plated RCA connectors
- Heavy-duty gold plated binding posts
- Balanced (XLR) and RCA inputs
- Both 4 and 8 ohm binding posts
- User selectable triode/ultralinear output
- Fully tested, burned-in, and auditioned
- Entirely designed and built in the USA
Specifications:
- Output power: 250 WPC
- THD: less than 0.1% typical, 1% at peak
- frequency response:
- 20Hz -25KHz at full output, 10Hz -100KHz at 10 watts
- Input sensitivity: 1.0V RMS
- Dimensions: 9.5" W x 24.5" D x 12" H
- Weight: 100 lbs each
- power requirements: 115V/230V - 50/60Hz
Apollo Dark Extended Features:
- Ultra Premium coupling capacitors
- Increased power supply storage
- Hex Fred high speed diodes in power supply
- Polypropylene bypass capacitors in power supply
- Nude Vishay resistors in critical locations
- Rhodium binding posts (Cardas)
- Rhodium RCA jacks (Cardas)
- Upgraded signal wiring (Cardas)
- Telefunken and RCA small signal tubes
- Black anodized CNC machined aluminum chassis
« Last Edit: 11 Apr 2022, 03:26 pm by Avinash »
