Power cable recommendations (simple, not expensive)
0 Members and 1 Guest are viewing this topic. Read 2232 times.
eastvillage
« on: 18 Jul 2021, 07:36 pm »
(I'm such a forum newbie I'm not allowed to search; I assume I'd find the answer if I could!)
I just set up my brand new DVA 225 monoblock amps, which sound just wonderful. I am really happy!
I'd be marginally happier if I could relocate my amps a bit out of reach of my outlets, given the stock power cords.
Frank (or anyone else), any particular power cords you recommend (same quality as the stock cord is fine).  I like the Blue Jean Cable p.o.v., but they don't make power cords!
thanks. Updates to come as I listen more.
SteveFord
Re: Power cable recommendations (simple, not expensive)
« Reply #1 on: 19 Jul 2021, 03:00 am »
Supra LoRad are pretty good and don't cost a fortune.
PSB Guy
« Reply #2 on: 19 Jul 2021, 03:29 am »
I use Tripp Lite 14 AWG cords on my AVA amp and DAC. They are similar to the ones Frank provides, just a heavier gauge. You can get them on Amazon at a very reasonable price, and they come in various lengths.
Cornelis
JackD
« Reply #3 on: 19 Jul 2021, 03:41 am »
Blue Jeans does make power cords but they are on the Iconoclast Cable website.  BAV power cords.  Other than that look at Cullen Cable or Signal Cable.
NIGHTFALL1970
« Reply #4 on: 19 Jul 2021, 03:41 am »
Welcome to AC and congratulations on your new AVA gear!
Doublej
« Reply #6 on: 19 Jul 2021, 10:52 am »
Monoprice 14 gauge, 10 or 15 feet depending upon your need.
https://www.monoprice.com/product?p_id=33669
eastvillage
« Reply #7 on: 19 Jul 2021, 12:22 pm »
thanks for these suggestions!
I.Greyhound Fan
« Reply #8 on: 19 Jul 2021, 02:08 pm »
Without knowing your budget, if you want something more custom, take a look at Cullen Cables.  They are built well with quality parts.  I use the Gold series but the Red series are good without breaking the bank.
https://www.cullencable.com/red-series/
https://www.cullencable.com/gold-series/
Patrick can make them in any length you want.
dpatters
« Reply #9 on: 19 Jul 2021, 02:41 pm »
+1 on Cullen Cable.
jtcf
« Reply #10 on: 19 Jul 2021, 03:27 pm »
Cullen cables are really excellent, right up there with the best.
Scroof Neachy
  • I like to smell stuff
« Reply #11 on: 19 Jul 2021, 06:33 pm »
What power cord parameters are being met (or exceeded) that would justify this statement? Price, value, electrical profile?
cheech
« Reply #12 on: 19 Jul 2021, 08:44 pm »
Don't know what your budget is , but possibly consider the entry level Audio Art Cable - power 1 classic.  For me it was the 1st reasonably priced power cord that my ears could actually hear an improvement from ; had previously tried PS Audio, Signal Cable and a few others. I have since moved up their line.
https://audioartcable.com/products/aac-p1-ac-15a-iec
twitch54
« Reply #13 on: 19 Jul 2021, 09:37 pm »
Tom Bombadil
« Reply #14 on: 19 Jul 2021, 11:55 pm »
Cornelis
+1
I went to a musician's store and purchased the Tripp Lite 14 AWG in 3' lengths.  About $7 each.   These can safely handle a continuous 1440 watt load.  They are well made.  I did compare them to a couple of $100-$200 audiophile power cables and heard no difference.   I believe they make them in 6' and 10' lengths.
