dual ob servo subs upper frequency limit?
0 Members and 1 Guest are viewing this topic. Read 807 times.
goryu
« on: 17 Jul 2021, 09:33 pm »
How high can the dual ob servo subs be used realistically? Looking for a way to use a line array of 8 neo8's as the midrange with my tympani ia's tweeter and ditch the two bass panels. Thanks.
goryu
Re: dual ob servo subs upper frequency limit?
« Reply #1 on: 18 Jul 2021, 03:30 pm »
Sorry if this was a dumb question. Thought someone would know.... :scratch:
HAL
« Reply #2 on: 18 Jul 2021, 03:35 pm »
You do not want to go above 250Hz with the OB servo subs.  That is why they are normally used with the BG NEO10's when they were available.  The NEO8's need another driver below 800-1000Hz as in the LS-6 or LS-9 speakers.
Danny is working on a NEO10 replacement, but have not heard any updates.  He maybe working with the GRS 10in planar as well.
goryu
« Reply #3 on: 18 Jul 2021, 04:47 pm »
thanks for your reply!
