Industry Circles
NuPrime Audio
rustydoglim
CDT-8 Pro Feet
CDT-8 Pro Feet
0 Members and 1 Guest are viewing this topic. Read 1520 times.
SRO
CDT-8 Pro Feet
16 Jul 2021, 09:27 am »
Really enjoy the CDT-8 Pro but I have one issue. Over time all the metal caps on the CDT-8 feet have fallen off. Is this an issue? Is it OK to leave them off or does it affect the isolation of the unit.? Thanks in advance.
rustydoglim
Facilitator
Re: CDT-8 Pro Feet
17 Jul 2021, 11:48 am »
Do you mean the silicone tip of the feet ? Can you show a photo?
If it is just the cover of the feet then it doesn't matter.
SRO
Re: CDT-8 Pro Feet
Reply #2 on:
17 Jul 2021, 11:54 am »
It is just the metal covers that go over the rubber. See picture attached. Based on your comment I think that you're confirming no issue with these covers off. Correct?
rustydoglim
Facilitator
Re: CDT-8 Pro Feet
Reply #3 on:
20 Jul 2021, 09:11 am »
That's just for the look only, it is the two-section silicone feet that provides the anti-vibration (the tiny round tip and the base have different stiffness). You can glue the metal cover back. It is the first time I heard that it has fallen off.
SRO
Re: CDT-8 Pro Feet
Reply #4 on:
20 Jul 2021, 10:42 am »
Thanks rustydoglim.
Craig B
Re: CDT-8 Pro Feet
Reply #5 on:
20 Jul 2021, 11:14 am »
I can't say that's happened with mine, though I haven't touched anything but its buttons since first setting it up, well over a year ago.
brucelee
Re: CDT-8 Pro Feet
Reply #6 on:
25 Jul 2021, 03:05 am »
My DAC9, CDT8 and two STA9 feet are all fell off. OEM should use better heat resistance glue.
rustydoglim
Facilitator
Re: CDT-8 Pro Feet
Reply #7 on:
28 Jul 2021, 03:51 pm »
Now then we hear about this
Thanks, I will feedback to factory to pay attention to the glue.
Industry Circles
NuPrime Audio
rustydoglim
CDT-8 Pro Feet
