Lithium batteries as power source
0 Members and 1 Guest are viewing this topic. Read 1518 times.
sarora9
« on: 14 Jul 2021, 03:13 am »
I was wondering if people here have tried Lithium batteries as power sources, especially for low-power components.
Enjoythemusic was recommending these a couple years ago. http://www.enjoythemusic.com/magazine/equipment/1219/Great_Audiophile_Gift/Goal_Zero_Yeti_400_Lithium_Portable_Power_Station.htm
I just received these batteries, which I plan to use to power my dac (also has a pre-amp). The DAC's power consumption is about 35W, so the battery charge should be good for a day's listening
https://www.amazon.com/gp/product/B082TMBYR6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
First impressions are very positive; better SQ  than the Torus TOT power conditioner I was using, and about 1/4th the price. Are there any downsides to using batteries?
Thanks for any insights.
Re: Lithium batteries as power source
« Reply #1 on: 14 Jul 2021, 03:22 am »
If power is suffice batteries are always better than raw AC power imo.
sarora9
« Reply #2 on: 15 Jul 2021, 03:03 am »
OK I discovered one shortcoming in the lithium-ion sources: a built-in fan that comes on regularly. A bit annoying. I guess one could look into replacing with a quieter fan but that would void the warranty.
Flyin_V
« Reply #3 on: 15 Jul 2021, 08:24 pm »
I use one to power my front end (streamer, DAC, DVD player, phono stage) and the fan almost never comes on. If I plug in my tube amp, the fan comes on quite a bit. Under no circumstances should anyone do this but I remove the top and Yeti will stay cool and quiet.
