Transcendence 10 SL
0 Members and 1 Guest are viewing this topic. Read 1204 times.
mako
Transcendence 10 SL
« on: 11 Jul 2021, 10:30 am »
 I just recently acquired a like new rendition of this preamp with stock tubes. I was wondering if there are any favorite tubes associated with it or if tube rolling is even worth the effort?
Mainewoods
Re: Transcendence 10 SL
« Reply #1 on: 12 Jul 2021, 06:15 pm »
Hello Mako, I replaced the Sovteks with  Reflectors in my T10 RB. I thought it was a worthwhile switch. They added some detail and air, solid bass too. Seemed to compliment the Synergy Double 240 I was running when I made the change. They sound great with the new SET 400 as well. It's likely you will hear the difference regardless of your choice of tubes. You can find a few comparative websites for guidance but really just have to try them out. I got the Reflectors from the TubeStore, Upscale Audio has an interesting selection too.
mako
« Reply #2 on: 13 Jul 2021, 10:13 pm »
Thanks for the recommendations Mainewoods. I think I will just enjoy the stock tubes for a while.
Mainewoods
« Reply #3 on: 14 Jul 2021, 08:27 pm »
Probably the best way to make good comparisons in the long run. Enjoy!
