AUDIOQUEST THUNDERBIRD BIWIRE COMBO SPEAKER CABLE (PAIR) 70% Off!!
0 Members and 1 Guest are viewing this topic. Read 480 times.
gfroman
AUDIOQUEST THUNDERBIRD BIWIRE COMBO 10Ft SPEAKER CABLE (PAIR) 70% Off!!
10ft. pair with Silver Spades.
Retail $9800, SALE $3100
This composite cable starts with two connectors on the amp side, then splits into two cable runs (one ZERO and one BASS), and ends with four connectors on the speaker side, two for treble, and two for bass.
Barely a year of use and in excellent condition.
They sound incredible with really unbelievable bass response and high frequency extension. We were blown away.
OG packaging included.
Solid Perfect-Surface Copper+ (PSC+) Conductors Solid conductors prevent electrical strand-to-strand interaction, major sources of distortion. Surface quality is critical because a conductor can be considered as a rail-guide for both the fields within a conductor, and for the magnetic fields that extend outside the conductor. The astonishingly smooth and pure surface of all AudioQuest's Perfect-Surface metals nearly eliminates harshness and greatly increases clarity compared to lesser materials. Extremely high-purity Perfect-Surface Copper+ further minimizes distortion caused by grain boundaries that exist within any metal conductor.
Carbon-Based Linearized Noise-Dissipation System (NDS) Today's environment is saturated with radio-frequency noise that is extremely difficult to filter or reject. The frequencies of this noise from satellites, cellular towers, and Bluetooth, etc., are so extremely narrow that a conventional shield, or a series or shunt filter, is wholly inadequate. Much of the low-level signal that carries the harmonics and spatial cues that define high-resolution audio is masked by induced radio-frequency noise. AQ's comprehensive Linearized Noise-Dissipation System combines multiple shields and a carbon-based linearized resistive network that turns most of this noise into heat. By "linearized," we mean that the system is equally effective across extremely wide bandwidth, rather than at selected frequencies only, as is more common. The remaining bad energy is effectively drained away from the sensitive amplifier circuits via directionally controlled signal and shield conductors.
« Last Edit: 6 Jul 2021, 01:05 am by gfroman »
gfroman
SOLD
