High Sensitivity 28B3 cube amp
0 Members and 1 Guest are viewing this topic. Read 2515 times.
Simm
« on: 28 Jun 2021, 01:50 am »
I have two 28B SST3 (cubed) amplifiers. The input sensitivity is so great that most preamps (including mine) can't use but about a third of their volume range. I have heard that Bryston didn't put in a switch to lower the sensitivity because it would have compromised the sound. Is that true? Has Bryston solved this problem by now? Any information will be appreciated.
Thanks.
Simm
  • The Demo is Everything!
    • http://www.bryston.com
Re: High Sensitivity 28B3 cube amp
« Reply #1 on: 28 Jun 2021, 10:22 am »
HI Simm
That is correct the safety certification would not allow for a switch on this powerful an amplifier.  The gain in the amp is 28dB which is average for most amplifiers.
I do not know what preamp you have but I would ask the manufacturer if you can lower the gain in the preamplifier.
james
Simm
« Reply #2 on: 29 Jun 2021, 11:11 pm »
Thank you for the prompt reply.
Simm
1oldguy
« Reply #3 on: 24 Apr 2022, 04:12 pm »
HI Simm
james
Hi James
Curious ..........Were some 28 Cubed amps set at 28db and some at 29?
« Reply #4 on: 24 Apr 2022, 04:47 pm »
They are all at 28
james
1oldguy
« Reply #5 on: 24 Apr 2022, 04:57 pm »
I was confused because you said they there were set at 29 when I asked, when I couldn't find the gain switch that doesn't exist on the 28's.
« Reply #6 on: 24 Apr 2022, 05:40 pm »
No there is not a gain switch on the 28B
james
