Firmware update for BDA-3.14 failed
0 Members and 1 Guest are viewing this topic. Read 1439 times.
WillyP
« on: 24 Jun 2021, 10:06 pm »
Hello James and Chris,
After my BDA-3.14 was powered on, Manic Moose showed the message “New firmware is available”. I saw all kind of messages about the BR-20, but I thought, let”s give it a try. Downloading went well but stopped at 78%. After that, the BDA-314 didn’t respond anymore. The only thing that helped, was shutting off the unit and removing the power cord for a minute. There is a direct connection between my BDA-3.14 and my router; I have updated the firmware a few times, with success.
After the unit was powered on, the message about the firmware was shown again.
Can you tell me what is going on? Is this update not meant for the BDA-3.14?
Thank you for your help.
WillyP
EvanMcC
  • Bryston, Dynaudio & Torus
Re: Firmware update for BDA-3.14 failed
« Reply #1 on: 25 Jun 2021, 12:23 am »
I’ve had a similar issue. Not even able to reach the update server from the looks of things. The browser just hangs.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 25 Jun 2021, 01:01 am »
I know Chris is working on the server tonight.
james
unincognito
    • bryston.com
« Reply #3 on: 25 Jun 2021, 01:55 am »
Hi All, we had to perform a bit of maintanance tonight which involved moving some hardware and caused the server to be offline for a short bit.  everything should be online again, please try again and let us know how you make out.
Chris
EvanMcC
« Reply #4 on: 25 Jun 2021, 12:09 pm »
Success!! Thanks guys!
Clive197
« Reply #5 on: 25 Jun 2021, 01:10 pm »
What version no is the new firmware?
WillyP
« Reply #6 on: 25 Jun 2021, 01:15 pm »
Still S2.44 but with a new date: 2021-02-26. Firmware update failed again!
WillyP
unincognito
    • bryston.com
« Reply #7 on: 25 Jun 2021, 01:41 pm »
Its a small change for the BR-20, because it uses a Pi 4 it wasn't detecting when new firmware was available because of a bug.  There is a bigger software update coming to fix a number of things and to give the BR-20 Roon Ready support.
