GR Desktop Mini
0 Members and 1 Guest are viewing this topic. Read 7154 times.
mkrawcz
Re: GR Desktop Mini
« Reply #40 on: 5 Jul 2021, 01:42 pm »
Danny just finished filming the build of his Desk Mini's today!
We hooked them up and let them play for a little bit and they kick butt! They image really well and offer great off-axis response, and offer plenty of detail and a balanced tone.
No complaints here! :thumb:
Ok what are those monoblocks?
Hobbsmeerkat
Re: GR Desktop Mini
« Reply #41 on: 5 Jul 2021, 06:02 pm »
Hey Killian/Danny/Hobbes
(or anyone with the info I don't have  :D )
I'm looking and the minis on the website. I see the flatpacks (unassembled) have the square edges.  The assembled versions have the round overs on the corners. Is not possible to offer the round overs in the un-assembled version too?
just curious... I suspect I could put a flatpack together... but that round over... well that's another story.
Sure, just give us a call after you place your oder to let us know so we can make note of it on the order & let killian know as well.
Hobbsmeerkat
Re: GR Desktop Mini
« Reply #42 on: 5 Jul 2021, 06:03 pm »
Those are a pair that are currently "in development."
corndog71
  • Some people call me Rob.
Re: GR Desktop Mini
« Reply #43 on: 5 Jul 2021, 08:43 pm »
Cool, now do an MTM version.
Hobbsmeerkat
Re: GR Desktop Mini
« Reply #44 on: 5 Jul 2021, 11:13 pm »
Can't, the woofers are 8-Ohm versions only. We would need a 4 Ohm tweeter.
Best we can do is MMTMM doing series-parallel connections.
Otherwise, we'll need to change the tweeter. Only thing right now is the Neo3.
RonP
Re: GR Desktop Mini
« Reply #45 on: 6 Jul 2021, 01:21 pm »
chop chop then. Time's a wastin'!  :lol:
ArmlessAudioMan
  • You're valuable, even if you don't feel it
Re: GR Desktop Mini
« Reply #46 on: 8 Jul 2021, 04:30 pm »
If I were building these speakers, I'd eliminate the posts all together. I'd figure the longest I'd ever need the speakers apart, divide that by 2, add 1'-2' for slack, then just extend the internal wiring off the crossover that length and terminate a spade on the other end.
I like out of the speaker box thinking like this. I was pondering the same idea. I'll put Tube Connectors on my more expensive projects, but for the mini, we'll see what I decide.
