Real VNC Viewer
0 Members and 1 Guest are viewing this topic. Read 1182 times.
Don_S
Real VNC Viewer
« on: 18 Jun 2021, 04:09 pm »
Is anybody using Real (not Tight VNC) VNC Viewer and Server? I am using it to control my music server from my desktop. It worked great and then stopped working. I will post details if someone can help.
A recent major update of W10 may have caused the problem. I can't remember if I used my audio system after that. I do know the update torched Fidelity Active Trader Pro.
Thanks for any help.
mooncrikit
Re: Real VNC Viewer
« Reply #1 on: 7 Sep 2021, 01:42 pm »
Hi Don. yes I use Real VNC viewer with my Datasat LS-10 Pre/ Pro...what seems to be your issue? Does your remote connection time out or something else? Jeff
Don_S
Re: Real VNC Viewer
« Reply #2 on: 7 Sep 2021, 02:22 pm »
Jeff,
Problem ended up being electrical, not software. Samsung SSD 980PRO is not being recognized by the server it is in. Therefore VNC could not find the device. My tech support is working on a solution to get the Samsung recognized.
Before everything functioned very well and I was a happy camper.
