0 Members and 1 Guest are viewing this topic. Read 3747 times.
….. I feel that Maggies give a more lifelike presentation.
Maggies will show the weakness of you gear with the first few notes.Isn't the truth. If the freezing wind sounds on Apostrophe are off you'll know whatever it is will never sound right.
Magnepan DWMs. I call them Dedicated Woofer Modules, 40 to 200 hz, That's All Folks. I purchased 2 over a 3 year period, money was tight. They were purchased to help out my MMGs, worked great. Now they augment my 1.7i s. They do a great job of adding life to low end. They will not move your pants leg like a JBL Century or other large woofers. Are they worth it, YES, for me. Tried two positions for them, next to the 1.7i and 2 feet inside of the 1.7i s. Seem to work best spaced 2 foot in from the mains. I also use a subwoofer swarm below 40hz with an electronic xover. I wired the DWMs each in series then in parallel with the 1.7i, presenting a 6 ohm load to the amplifier.I am contemplating a pair of 10 inch woofs in a small cabinet for 40 to 300hz to get some of that JBL Century sound. I am not sure whether to go sealed box or another configuration.
