Magnate strength and position for driver covers
0 Members and 1 Guest are viewing this topic. Read 634 times.
Ethan Macfarlane
« on: 3 Jun 2021, 12:29 pm »
How many and what strength magnates (I'm planning on using 10 diameter) has everyone used for driver covers for the x ls/x sls?
Thanks in advance!
Ethan
Peter J
  • Hmmmm
Re: Magnate strength and position for driver covers
« Reply #1 on: 3 Jun 2021, 01:16 pm »
 I've come to like smaller diameter for most grills. N52 Neodymium, 1/4" x 1/4" or 1/4" x 3/8". Sometimes a combo of the two. In most cases, eight would be plenty on smallish grills such as X-LS. Four on grill, Four on cabinet. I also like to put a felt pad over magnet on grill itself to protect finish and facilitate "sliding" the grills off.
Also depends on actual grill weight which can vary some. MDF or ply, NoSeeUm net or traditional grill cloth, etc.
Be conscious of polarity when gluing in place.
ColinGreyvensteyn
« Reply #2 on: 21 Jul 2021, 12:22 pm »
Do you make your own grills? I'm about to DIY a set of speakers and am curious how to go about grills? Or do you buy some and fit them afterwards?
