0 Members and 1 Guest are viewing this topic. Read 2421 times.
Before I drop nearly $1k on some speakers I'd like to hear some more opinions. Though I sense wharfedales are prob good for the money as well, but quite frankly the exclusivity of Salks… even the "cheap" ones has a strong appeal to me as I feel like I'm started to walk down that alluring path to far to go back if I'm being honest.
The music is coming from my PC and my current plan as has been suggested to me as I also want my headphones to use the same output on my pc. I'm looking at:Yamaha A-S501 > Salk Surround 1 and possibly/likely a 10" svs subwoofer down the road. Use the headphone line out to a proper headphone amp for my small collection of $200ish headphones. Also the a-s501 has the ability to connect a bluetooth component to it which I can appreciate.
I own a pair of DIY CAOW1 speakers, which I made in 2005. They were originally designed by Dennis Murphy, and quite frankly, they sound excellent. They're essentially the same speaker as the Song Surround I. There is a rather small difference between the crossovers of the CAOW1 and the SSI (don't worry about that), the SSI's woofer is close but not identical to that in the CAOW1 (again, don't worry), and Jim Salk's cabinet finishes are way above my pay grade. I highly recommend any of his standard veneer finishes. They look better than any furniture I've owned.The redditt review that recommended the Salk SSI steered you in the right direction. Dennis Murphy, in addition to a most excellent speaker designer, is a musician. He plays violin, viola, and piano, mostly classical music. His knowledge of what real musical instruments sound like led him to design speakers because nothing commercially available came close. His speakers are (in my opinion) the world champs at creating a believable audio image of a musician sitting in your room, as opposed to a tiny musician sitting inside the speaker cabinet. The critical mid-range sounds clear, detailed and present, without being crisp or etched sounding. To my knowledge, all his designs accomplish that, even the inexpensive SSI. If you pay more money, his designs can produce lower bass or more refined high frequencies, but they all share that mid-range quality.The Yamaha A-S501 should provide enough power to drive the SSI speakers nicely. They can handle greater power, but that Yamaha's 85 wpc should be enough.My own experience with my CAOW1s has been with two different amps. I first drove them with an old 30 wpc stereo receiver, a Marantz 2230. It was a bit underwhelming. I now use that same receiver as a pre-amp to drive an external amp that produces 105 wpc (a B&K ST-140). Going from 30 to 105 wpc (about triple the power) made a very noticeable improvement. Years ago, I tested a Yamaha A-S701 on my speakers, and it drove them well. I haven't heard that Yamaha A-S501 in action, but I suspect it will be good enough.The SSI can go as low as 50 Hz without a sub-woofer. So listen to that first, before deciding on a sub-woofer.
Seems most Salk consumers are getting there tower systems that are well beyond anything I need or would like to spend... esp after my first home purchase. Though I'm still rather surprised there arent alot more reviews/owners of these speakers. Usually entry level to truly premium retail goods are a heavy portion of most manufactures (well.. so I would assume) And while I'll admit I may be confirming my own biases.. It is nice to hear similar opinions. And with all due thanks, still I would very much like to hear from an owner.
How is your evaluation of them as near field? I would assume 2-4ft away would be minimum 60% of my listening time with them.
