A-300 Omnia mostly awesome!
0 Members and 1 Guest are viewing this topic. Read 1674 times.
Sonic Peter
« on: 24 May 2021, 10:09 am »
Really loving the new a300. Sounding fantastic into a pair of Monitor Audio Silver 500's. Only issue I have is it will not connect by Ethernet, only wifi. Does anyone know how to get it hardwired. I have ruled out faulty cords and ports, it's the streamer. Please help?
rustydoglim
    • www.nuprimeaudio.com
Re: A-300 Omnia mostly awesome!
« Reply #1 on: 25 May 2021, 04:26 pm »
For sure it will work with RJ45 ethernet connection. if it is connected to your router, you don't even need to setup the WiFi on A300.
You might want to contact support if you still have the problem.
Sonic Peter
« Reply #2 on: 25 May 2021, 08:47 pm »
Ok will do, thank you
Sonic Peter
« Reply #3 on: 15 Jun 2021, 12:52 am »
Update: the modem I am using is incompatible, tried our other modem and work perfect!
