Industry Circles
Bryston Limited
B100/B135/BP17 rec button
0 Members and 1 Guest are viewing this topic. Read 624 times.
GrooveControl
23 May 2021, 02:32 pm »
Hi All, does the rec button function like a tape monitor switch, or is it just another input? The manual is not clear on this.
If you select rec, and then select another input, does rec remain lit?
Thanks in advance.
fbny71
ยป
Re: B100/B135/BP17 rec button
24 May 2021, 01:55 pm »
The Rec button does indeed act as a tape monitor. You can select another input and record/monitor. You could also just use it as another unbalanced input.
Industry Circles
Bryston Limited
