230. V integrated
0 Members and 1 Guest are viewing this topic. Read 839 times.
Ragnar71
230. V integrated
« on: 23 May 2021, 08:04 am »
I’m asking here because there always seems to be a lot of knowledgeable people on here including Danny.
If you get a integrated from Japan that uses 230 , is a step up transformer the only way to get it to work and if you use a step up transformer does it affect the performance
nickd
Re: 230. V integrated
« Reply #1 on: 23 May 2021, 04:41 pm »
A properly sized step up transformer would be fine. I nice transformer will likely be large and may add quite a bit to your set up cost.
 It may also be possible for a shop to rewire the internal transformer or power supply for 120v some times it’s just a couple of dip switch’s, moving a fuse or two, etc..  Manufacturers that sell to multiple countries sometimes have options inside the case. Best left to a knowledgeable tech with a schematic..
Hope it works out for you.
HAL
« Reply #2 on: 23 May 2021, 05:03 pm »
Some Japanese gear has a 100VAC@60Hz AC power capability.  That would be more prevalent than 230VAC@50Hz.  That is more typically UK/EU AC power.
Is there a chassis switch for selecting different AC voltages?
bellavita
« Reply #3 on: 23 May 2021, 06:55 pm »
I have 3 units from Japan 100v.This transformer works fine and they sound wonderful.Made in USA ACUPWR.
https://acupwr.com/collections/japan-to-usa-transformer-converter-use-100-volt-appliances-in-110-volts-countries
Cheers
