Industry Circles
Bryston Limited
Dac in B135Cubed Dac
0 Members and 1 Guest are viewing this topic. Read 786 times.
wplash666
20 May 2021, 05:22 am »
What would it compare too? Would the BDA-3 be better, and how much?
GSDaudio
Re: Dac in B135Cubed Dac
20 May 2021, 11:49 am »
Hi wplash666,
I can't speak for the B135 dac but I recently updated from a BP26 dac which is pcm 96/24.
I went with the BDA-3.14 which has the same dac as a BDA-3. SQ improvement was big. Well worth the value in $.
If you want usb or HDMI inputs go with BDA-3. USB is a must if you don't have a BDP feeding your dac.
If you want DSD go with BDA-3.
Hope this helps!
Francois_Tardif
Reply #2 on:
20 May 2021, 12:44 pm »
Hi wplash666,
My setup is a BDP-3 + BDA-3. I had the opportunity to have a B135Cubed during a full 2 weeks. I was in heaven, so I ordered one that should arrive next week… I never thought that my speakers could sound like this. WOW!
François
wplash666
Reply #3 on:
20 May 2021, 09:54 pm »
I think GSDaudio pretty much convinced me I need to start looking for BDA-3 or 3.14, thanks.
Industry Circles
Bryston Limited
