2 Piece Bugle 90% done *pix*
0 Members and 1 Guest are viewing this topic. Read 1678 times.
BillEpstein
« on: 15 Mar 2005, 03:31 am »
Struts need some adjustment and pre-cat lacquer applied but I went 2 days with the FLU and w/o real (vinyl) music and had to set it up. Now that it's playing it could be months or years before I take it down to finish :mrgreen:
The XLR was a snap thanks to Jim's advice. The one thing I would change is it's position but it avoids all power wires crossing all signal wires.
The case is Mahogany and Gaboon Ebony which is used to make fretboards and Clarinets so it must have magical, musical effects on the component at the Quantum level.
The Cocobolo knob switches between analog and digital.
DeadFish
« Reply #1 on: 15 Mar 2005, 04:19 am »
That setup for both units looks pretty clever, Bill!
I like the idea.
You are liking your Bugle, I take it.
It has been on my 'short list'  to replace what I've got and what you did encourages me.  I like 'clever.'  :)
Happy Listening!
DeadFish
JoshK
« Reply #2 on: 15 Mar 2005, 04:14 pm »
Very cool!
Glad to see that it worked out for you.  You used XLR connectors right?
