Subwoofer Enclose Repurpose
0 Members and 1 Guest are viewing this topic. Read 1830 times.
konut
« on: 11 May 2021, 05:11 pm »
I have this old UFW-12 that does not work. Is it possible to put blocks of styrofoam(or some other substance) inside to lessen the volume for a different 12" woofer? Would the woofer "see" it, or still "see" the total volume of the box? That would be a more attractive option than cutting a hole for a 15" woofer.
mcgsxr
Re: Subwoofer Enclose Repurpose
« Reply #1 on: 11 May 2021, 11:42 pm »
You could insert pieces of wood to “shrink” the effective size of the box.  I’ve done that with car subs before.
Doublej
« Reply #2 on: 11 May 2021, 11:53 pm »
Why does a subwoofer box with a 12 inch driver need to be reduced to put in a different 12 inch driver? Couldn't you find one spec'd for the same size box?
konut
« Reply #3 on: 12 May 2021, 09:41 am »
That would be quite lucky! The 12s I'm considering call for a smaller box for optimal loading.
konut
« Reply #4 on: 12 May 2021, 09:45 am »
Thanks! The reason I suggested Styrofoam is for weight considerations as the box is quite heavy. Does the density of the "filler" enter into the equation? Hmmm? :scratch:
mcgsxr
« Reply #5 on: 12 May 2021, 11:12 am »
I have read of expanded polystyrene being used.  Unclear if actual styrofoam has the density.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #6 on: 12 May 2021, 11:16 am »
As I remember, the Rocket UFW-12 was a sealed sub. You may have to do nothing in all honesty. I would first implement the new 12 inch, make measurements, before adding wood blocks to reduce the acoustic volume. Sealed subs are highly forgiving.
A larger box gives you a lower Qtc and deeper bass extension (lower F6 and F10) than a smaller box. It may sound tighter/cleaner, but that strongly depends on room placement and quality of the woofer you are replacing it with.
If it were me, I would do nothing and just replace the woofer.
If it’s ported, ignore the above, it will need a redesign.
Best,
Anand.
konut
« Reply #7 on: 12 May 2021, 11:21 am »
Thanks for all the responses.
