BCD-1 vs BCD-3
0 Members and 1 Guest are viewing this topic. Read 1272 times.
Sco77
BCD-1 vs BCD-3
« on: 6 May 2021, 09:03 pm »
I have a BCD-1.  It will play up to track 37 on a CD I have that has 99 tracks.  I believe that James Tanner said that this was a function of the CD drive used in the BCD-1.  Is the CD drive used in the BCD-3 capable of playing all 99 tracks?  It's time to evaluate upgrade possibilities and I'd like something that will handle the 99 track specification that's part of Redbook.
redbook
  • the music is the blood...........
Re: BCD-1 vs BCD-3
« Reply #1 on: 6 May 2021, 11:44 pm »
  Good question. The BCD-3 uses the drive from Stream Unlimited. It seems a better device than the Phillips was but not sure about the max tracks.... :scratch: In any case I had the BCD-1 and although it was a very fine player my BCD-3 surpasses it in over all refinement....you won't be disappointed if you get one.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BCD-1 vs BCD-3
« Reply #2 on: 7 May 2021, 10:58 am »
Hi Sco77
Yes the BCD-3 will play 99 tracks.
james
