The solution to your major room acoustics problems. . .
0 Members and 1 Guest are viewing this topic. Read 1673 times.
Hantra
Everyone knows that there are problems with corners in rooms when dealing with acoustics.  Luckily the guys in Germany have been thinking and have come up with THE solution for us.
That's right!  Why FIGHT with your corners?  Use them to your advantage!!!  :lol:
8thnerve
Re: The solution to your major room acoustics problems. . .
« Reply #1 on: 14 Mar 2005, 01:51 pm »
Quote from: Hantra
You know, I have been fascinated by these for years.  I think if you had four of them, two in the top left and right corner, and two in the bottom left and right corner, it would sound great, of course you'd have to sit on the center axis of the room, etc.  And perhaps process so that the upper channels had a higher volume, etc.
Or you could just build speakers into acoustic products...
Hantra
« Reply #2 on: 14 Mar 2005, 02:29 pm »
Quote from: 8thnerve
I never thought of it that way, but I suppose you're right.  These will at least hold me off until your new products arrive at my place.   :wink:
