Help with hum/hiss.... Thanks in Advance
0 Members and 1 Guest are viewing this topic. Read 956 times.
TKonrad.NOLA
« on: 28 Apr 2021, 01:02 pm »
I have a VPI Prime Scout, Cary Audio SLI 100, MoFi phonostage and a Furutech phono cable.  The cable had a flimsy ground wire attached that broke so I purchased an audioquest ground wire.  I can't ever remember the background being dead silent but recently I noticed it is to a point where it is bothersome.  If I touch the grounding connection on the table, the noise disappears.  Should I A, replace my phono cable?  B, replace my phono stage?  or C all of the above?
rollo
  • Rollo Audio Consulting -
Re: Help with hum/hiss.... Thanks in Advance
« Reply #1 on: 28 Apr 2021, 06:27 pm »
 Run a separate ground wire from phono stage to AC outlet ground and be happy. :thumb:
charles
TKonrad.NOLA
« Reply #2 on: 28 Apr 2021, 06:31 pm »
Thank you, I will give it a try
charles
rollo
« Reply #3 on: 28 Apr 2021, 07:24 pm »
  Cool, enjoy the result.
charles
Fuse
« Reply #4 on: 6 Oct 2021, 12:13 am »
Connect the phono signal ground to the AC mains ground? Really? Aren't those two separate issues?
