Question About using a Power Tranny with Two 6.3v Secondaries for Tube Amp
0 Members and 1 Guest are viewing this topic. Read 1623 times.
Ericus Rex
I'm guessing the original intent of this trans is 6v tubes and 6v tube rectifier.  My project will use SS rectification.  Would there be any pros, or cons, to using one of these secondaries for the power tubes and the other for the input tube?  It's a 3 tube SE design, one 6DJ8 and two 6BQ5s.
Would be useful discover the amperage value from the transformer to see if it will have capacity to drive the 6DJ8, which are small only 365mA. Tube rect tubes eat a lot of energy from the transformer.
Ericus Rex
Each of the 6.3V secondaries is rated at 3A.
It will be a very robust transformer, the 6DJ8 are rated only 0.365A.
Drrick007
No problem, but check the voltage at the tube socket. With that much excess current capacity you may need a low value resistor to get the voltage down to 6.3 VA|.
Peace,
Rick
mgalusha
+1, you may need a small resistor in series to drop the heater voltage.
