SOLD Musical Fidelity M1HPA Headphone Amplifier & Preamp-Class A-High Power
0 Members and 1 Guest are viewing this topic. Read 788 times.
bixby
Original List Price - $799
Selling Price - $360
SOLD on the bay
This is a Class A headphone amp with plenty of power and the ability to drive two headphones simultaneously.  Output impedance is less than 1 ohm and the power supply is carefully regulated for incredible quiet black background.  It is in very good  (8/10)  condition cosmetically and performs flawlessly.  Very light wear consistent with normal use.  It has been used sparingly powering my Sennheiser HD-600s beautifully.
It includes a pre-out so you can use it with powered loudspeakers on a desktop and also has a USB input and built in dac to listen to Youtube videos or web music.  It is limited to 16/48 max and is okay but you really must use a much better dac to hear what this amp can offer.
As with most class A amps you get superb deep and controlled bass, spacious and natural mids, and silky highs.  Spatial cues, reverb and depth are beautifully presented.  Some have described the amp as slightly warm and I would agree, but not muddy, congested, or veiled, and absolutely non-fatiguing.    Details are clearly separated and soundstage is excellent. Several key capacitors and resistors have been upgraded to further improve sound.
Specs from Musical Fidelity:
Output Power                              1.1 watt (1100 millliwatts) into 32 ohm
Output Impedance                      less than 1 ohm
Output Level                               5.2V RMS max
Frequency Response                   15hz to 75kHZ – 3db max
Signal to Noise                            >109 db A wtd
Total Harmonic Distortion         <0.008% 10HZ to 20kHZ
Purchase includes the amp, U.S. Power cable and original box and packing.  Shipping is a flat $25 Conus Only and is SIGNATURE REQUIRED.
« Last Edit: 19 Apr 2021, 07:47 pm by bixby »
audioholic1976
Just to add some praise for this headphone amp.
The MF M1 series I call 'Switzerland', they are the most neutral and detailed gear you will find at this price and far above.
It is almost like it doesn't get in the way of what the artist wanted the music to sound like.
ServerAdmin
Please put your asking price back as CLEARLY STATED in the red box above your ad.
bixby
oops, my pleasure
