0 Members and 1 Guest are viewing this topic. Read 4290 times.
Hi, here are some numbers, for what they're worth: https://wcp.hunterdouglas.asia/br/br_Duette.pdf
I use a combo approach for my windows. I use wood slats on the interior of my windows (diffusion) and then heavy linen roman shades over the top of the window frame (absorption). I find that both together work better than either alone. And better than the cellular shades.
How much if any light comes through?
One other option to consider (not mutually exclusive with the blinds) is the Clearsorber product from RPG:...I had purchased some grey Vicoustic Multifuser DC2s after contacting you about a system picture from your gallery.
