Bryston 2018 BDA3 SW
0 Members and 1 Guest are viewing this topic. Read 623 times.
BWPhil
« on: 10 Apr 2021, 08:54 pm »
Hi:
I have a 2018 Bryston BDA3. In 2020, I did a SW update and that was not applicable to prior 2020 BDA3. I had to revert to another version of the SW.
Don’t know if the AES-EBU interface was working prior to the SW update or not as I had not used it previously.
Recently I want to use the AES-EBU interface, but the BDA is not locking onto the signal; I tested the AES-EBU output from my BDP2 to another DAC, and there is no problem.
The link built in the BDA3 for SW update does not work any more, and there is no download from Bryston web site.
I am looking for the latest SW for 2018 BDA3. I am hoping that reinstalling the SW will fix the AES-EBU interface on the BDA3; I don’t think it would have left the Bryston factory if the AES-EBU interface did not work, but I had not used it before.
Please help.
Thanks in advanced.
Phil
