Capacitor Upsize on Power End
0 Members and 1 Guest are viewing this topic. Read 1010 times.
Escott1377
« on: 10 Apr 2021, 02:21 pm »
I purchased a new pre amp from Musical Paradise that allows lots of tube subs as well as capacitors.
The input caps on the power side can go up to 10 UF.
I have read differing opinions on the web from the skeptics to the believers.
I am considering upgrading to the largest size and wanted to know if an “audio grade” capacitor will make a difference.
Right now I have some nice Clarity CMR caps rated at 2.2 UF in the pre in this position.
I have bee eyeing the Obbligato Ultra Premiums since they will fit.  The Mundorfs that I ordered were just too big for the box.
Any opinions please?  Is it something that I just go to Mouser for?
The Obbligatos that I mentioned are not terribly expensive from Parts Connexion when considering other choices.
For reference, I am using Jantzen Silver caps for output, but may change as well since they sound somewhat bright to me.
All suggestions are greatly appreciated and thanks in advance.
