Industry Circles
GR Research
Danny Richie
x-sls build
x-sls build
0 Members and 1 Guest are viewing this topic. Read 1090 times.
DJB
x-sls build
10 Apr 2021, 01:23 pm »
port location is front port ok and where to locate
Allumnus
Re: x-sls build
11 Apr 2021, 08:52 pm »
As far as I know, when you place them relatively close to the wall the port needs to be in the front.
Hobbsmeerkat
Industry Participant
Re: x-sls build
Reply #2 on:
12 Apr 2021, 02:58 am »
Yes, for close-wall placement of the SLS you actually have 2 options.
Front porting, or plugging the port with a foam plug, creating a sealed cabinet.
DJB
Re: x-sls build
Reply #3 on:
12 Apr 2021, 01:11 pm »
ok is same area only on front ok
Industry Circles
GR Research
Danny Richie
x-sls build
