balanced or single ended?
0 Members and 1 Guest are viewing this topic. Read 803 times.
stereoal
« on: 4 Apr 2021, 06:55 pm »
I have two CD players in my Bryston system. One is connected to my BP26 preamp with an interconnect. The other is connected to my BDA 3 with a digital coax cable.
My question is should my 7Bsst2 amps be set to single ended or balanced.  I have them set to balanced with the gain at 2V.
Thanks for your help.
« Last Edit: 4 Apr 2021, 08:16 pm by stereoal »
  • The Demo is Everything!
    • http://www.bryston.com
Re: balanced of single ended?
« Reply #1 on: 4 Apr 2021, 07:09 pm »
Hi
I typically use Balanced an 1 volt setting but there is no wrong or right - its usually a matter of how much gain in have overall in the system.
james
