Dawkimi, here’s what I did for my 3000+ sqft house:
200 amp service with power supplied by my own transformer just outside the service entrance.
Whole-house surge protection and professionally designed and installed lightning suppression system. This includes numerous spikes on the roof and rods and plates buried around the house. Everything electrical is tied into this massive ground system. The result is a very quiet electrical environment. It also helps that I am in the middle of nowhere with no enviro ...
Why are you so sure of that? No doubt you are in a better situation than an urban dweller, but "quiet"? I wouldn't be so sure.
If you already haven't, do try connecting an oscilloscope to your mains socket from which you draw power for your audio. Sweep from 60 Hz to 80 kHz - I think you'll be shocked at how "quiet" your environment is, but bear in mind, in urban areas, it's even worse. Often far worse.
What is all too often forgotten is that noise and pollution travel along with the power from the generating source onwards. And noise does not diminish with distance, although it changes in form somewhat.
The point being that no matter what you do, without a power line filter ("conditioner" my, er, sitting region) there is no getting rid of the noise and pollution. Installing a 20 amp socket only opens the door wider to the noise, although it does present a lower source impedance to the electrinics plugged into it.
Which, by the way, also introduce line pollution all by themselves and send it back into the other components on the same line. To the best of my knowledge, the only way to tackle that is to use parallel filter sections. So, it's not just any power line filter, since most don't do this, they bundle it all together.
DVV
