Any Rega experts out there ?
0 Members and 1 Guest are viewing this topic. Read 1014 times.
2bigears
« on: 27 Mar 2021, 09:04 pm »
 :D hello,  on a P9 TT I have a double pulley or two same size belt grooves on the drive pulley.  So does this mean I need to run two belts ?  The white belts sell for 100.00 bucks here !!  They don't make the white belts any longer for some reason. So this fellow must have old stock @ 100 a pop.   :D
toocool4
Re: Any Rega experts out there ?
« Reply #1 on: 27 Mar 2021, 11:11 pm »
I don’t believe you have to run 2 belts but running 2 will spread the load over double the area hence less stress on the belts.
I don’t have a Rega but I do run 2 belts on my turntable, I could just as easily run 1.
2bigears
« Reply #2 on: 27 Mar 2021, 11:31 pm »
 :D yes thanks. Rega belts are 85.00 now.  Holy smokes things are really going up these days.  190.00 for both belts plus tax.  Good lord. Just doesn't seem right.  :D
SteveFord
« Reply #3 on: 28 Mar 2021, 12:05 am »
I'm cheap so maybe look non OEM?
https://www.lpgear.com/product/REGAP9BELT.html
2bigears
« Reply #4 on: 28 Mar 2021, 01:10 am »
 :D. Thank you very much indeed.  I will get belted here. They are way better prices.  :D
PierreB
« Reply #5 on: 28 Mar 2021, 01:55 am »
If your P9 have a double pulley, go with 2 belts.
You have a nice TT.  :thumb:
2bigears
« Reply #6 on: 28 Mar 2021, 03:13 am »
 :) it sure does. Thanks you guys. Those white belts are not worth 90 dollars a piece. They are no longer made so that tells you something too.   :D
