HDMI Audio-Video-Problem Help!
0 Members and 1 Guest are viewing this topic. Read 830 times.
Barilko
« on: 21 Mar 2021, 08:22 pm »
Hello All
1st off I wish I could find a more attractive thread name (sorry)
Here is my quandary
I have an older but very solid Surround sound receiver  a Rotel RSX 1057
I use this for 5.1 Movies Concerts etc..
All along when it came to TV Movies i never had a problem as my Bell Fibe Box (I'm in Canada) has HDMI out and a separate Digital Audio out
I plan on moving to Videotron (as i save a significant amount of monthly coin) however there Box only has a HDMI out containing video and audio in one
My issue is the Rotel will pass the video through however it only will process audio in via RCA or Digital Optical or Digital COAX
so excuse my ignorance  and i will ask
is there a box/unit whatever that imports a HDMI containing audio and video that would split out the video and send it via HDMI
while splitting out the audio and sending it to my Rotel via COAX or Optical
any help and suggestions would be very much appreciated...
Thanks  and Cheers  Be Well...
WGH
Re: HDMI Audio-Video-Problem Help!
« Reply #1 on: 21 Mar 2021, 09:45 pm »
You need a HDMI Breakout Box, it splits the audio and video signals. The boxes are very affordable but I have never used one so don't know the best brand to get.
One feature to note is some only output stereo and some have 5.1 Dolby and DTS SPDIF outputs.
Your choices in Canada may be different, here is an example:
4K HDMI Audio Extractor Splitter, avedio links 1080P HDMI to HDMI Audio Converter + Optical Toslink SPDIF + RCA L/R Stereo Analog Audio, HDMI Audio Adapter for Chromecast, Fire Stick, Blu-Ray Player
https://www.amazon.com/LinkS-Extractor-Splitter-Converter-Chromecast/dp/B00XJITK7E/ref=sr_1_5?dchild=1&gclid=Cj0KCQjw3duCBhCAARIsAJeFyPXC6BE5FMk29tGoguc4j8qXcY4W5N8sWZn6GWM8R1u7mETcgL0Kk2kaAu2OEALw_wcB&hvadid=233485107297&hvdev=c&hvlocphy=9030244&hvnetw=g&hvqmt=e&hvrand=11302130659168146232&hvtargid=kwd-11931579709&hydadcr=18887_10145554&keywords=hdmi+breakout+box&qid=1616362075&sr=8-5
Barilko
« Reply #2 on: 22 Mar 2021, 03:33 am »
@WGH   Thank You.. I have been reading up quite a bit since posting this...  not the most interesting thread that is for sure  30 plus views and your 1 lone reply    however ill say a big Thanks as that is very helpful info and much appreciated..so Thanks again
