0 Members and 1 Guest are viewing this topic. Read 3744 times.
Your comments seem correct given I have the Luxman M900U that can double output into the lower impedance--and it was an expensive amplifier. While that is a cool spec., I don't know that paying the high cost got me greater listening pleasure. I also have an NAD 275BCEE (a relatively cheap amplifier) that has the same output, 150 watt/channel at 4 or 8 ohms and I really can't hear any difference between the two. Perhaps my habit of listening at relatively low volume is part of the reason I experience that. Perhaps the Luxman would shine at ear splitting levels!
There's some truth in that. Doesn't even have to be ear splitting levels, just levels that approach live non amplified music.
Of course it does matter with speakers that are 4 ohm or lower and low sensitivity. That Luxman probably would not break a sweat but the NAD might with such speakers.
Not only do your listening levels matter, but more importantly the thing that matters is the load your speakers present to the amp. If you listen at low levels and are using low sensitivity speakers, you're not likely to get great sound regardless of amp you use. Some speakers simply don't sound good at low levels. KEF LS50's are the perfect example of this. They are pretty low sensitivity and not an easy load. One should really get speakers that are suitable to one's preferred listening levels, room size, and listening distance...which can take a lot of trial and error.
Based on some of the responses, perhaps the reason I don't hear a difference between amps is the speakers are Harbeth 40.2 which allegedly are easy to drive. They are rated at 8 ohms and maybe dip to 6.
I appreciate all the thoughtful answers. A few posters said the Harbeth are easy to drive which could affect sound while another said they were hard to drive. If memory serves, Harbeth advertised the 40.2 as easy to drive I'm guessing because the impedance doesn't drop very low. But a lot of folks pick up on the efficiency of 86db. to make the claim they are hard to drive. I rarely turn my amplifiers up very high since there always seems to be plenty of volume so I'm wondering what the opinions are out there on the 40.2 being easy or hard to drive. Perhaps it's in-between?Thanks!
