Shunyata Alpha USB 1.5 meter 50% Off!!
0 Members and 1 Guest are viewing this topic. Read 454 times.
gfroman
« on: 18 Mar 2021, 10:21 pm »
- Like NEW condition with Certificate and Tag.
New $1200, SALE = $625
ALPHA cables feature Precision Matched Z conductors.
Signal and power wires are heavily shielded for superior noise immunity.
Each Alpha USB cable is handmade.
Description:
Digital signal and USB cables possess extreme sensitivity to proximal noise because of the environment they are applied within. The Alpha USB possesses a uniquely applied 100% coverage silver-mesh shielding to minimize exposure to radiation from nearby noise sources. Due to the high-speed nature of the digital signal, the Alpha conductors and termination junctions are perhaps the most critical aspect of any digital cable design. Caelin Gabriel uses his own proprietary design process called Precision Matched Z conductors which eliminate conductor incongruities that would otherwise distort high-speed signal transfer. To finish the Alpha USB design, custom-manufactured connectors are hand-applied using an alloy developed to eliminate junction related distortions inherent in all standard USB cable designs. The performance gain from these material refinements makes the Alpha USB the first choice for performance anywhere near its value oriented price.
gfroman
Re: Shunyata Alpha USB 1.5 meter 50% Off!!
« Reply #1 on: 26 Mar 2021, 01:04 am »
$590 + shipping
