What cables YOU think work best with Bryston=>PMC systems
0 Members and 1 Guest are viewing this topic. Read 1965 times.
Alfalfa
I know theres more topics about what cables to use with either Bryston OR PMC. Now, I'd like your opinions on systems that comprise PMC AND Bryston. What do YOU think works best between PMC and Bryston (and Bryston pre-power amps?). Which make or type of cable best matches the synergy between these brands? I know Bryston and PMC don't bother much about cables, but since I'm in the proces of selecting some, why not ask peoples own experiences.
Please only answer for Bryston(pre/power)/PMC combinations as there's already another cable topic on either bryston or pmc cable experiences..
I'm curious!!  :mrgreen:
rhart
« Reply #1 on: 28 Mar 2005, 09:49 pm »
I use Van Den Hul c122 speaker cables (bi-wired usually) and D102 MKIII and MkII cables with my Bryston 3B-ST and PMC DB1s. I haven't really compared other cables (other than some DIY Belden ICs). I'm happy with the sound I get.
Alfalfa
« Reply #2 on: 29 Mar 2005, 07:41 pm »
Thanks for the reply rhart, at the moment I'm also using Van den Hul speaker cables (Magnum) which I had still lying around somewhere. I'm using about 20 cm on each side and havn't really compared other cables (would it make a difference on such short lengths?) Since I've been moving the Bryston 7B ST's very close to the PMC monitors, I've noticed a huge increase in power reserves and dynamics. The sound became more effortless as they say.
Between pre and power amps I'm using MIT 330 Proline XLR interlinks (12 feet). It is of the medium impedance type, which describes the input impedance of the power amp. Although the Bryston power amps have what they describe as a low input impedance, I've read on some internet review that these cables worked very well with a Bryston 4B ST.
I wonder if anyone (at Bryston) has experience with these 'input impedance-specific' interlink cables and would care to describe his/her experiences with these cables with built on boxes??
Oh yes, between Musical Fidelity Nuvista 3D cd-player and Bryston BP20 preamp I'm using a DIY cable.
