SOLD... Nordost HEIMDALL 2 TONEARM CABLE / 1.2 meter $475.00
0 Members and 1 Guest are viewing this topic. Read 301 times.
undertow
SOLD
HEIMDALL 2 TONEARM CABLE +
The tonearm lead is one of the most critical audio cables in an analog system. As such, it demands a purpose-built, low capacitance conduit, in order to maximize the authentic and natural musical reproduction that LPs offer.
The Heimdall 2 Tonearm Cable + is virtually noiseless, with rapid transmission speed and the highest bandwidth capabilities, thanks to its twisted pair design, individualized shielding, and Nordost’s proprietary Micro Mono-Filament technology. It also employs a separately shielded, silver-plated bond wire, wrapped in Micro Mono-Filament, to minimize noise from the line. However, the most exciting aspect of this cable design is its revolutionary grounding solution. Nordost has introduced detachable ground whips, complete with Micro Mono-Filament technology, that further eliminate any noise that could be introduced during signal transfer, regardless of the unique construction of the components found in each individual sound system.
Nordost Heimdall 2 Tonearm +
SPECIFICATIONS
Insulation:       Fluorinated Ethylene Propylene (FEP)
Conductors:       4 x 28 AWG
Construction:
    2 Twisted pairs individually shielded. Mechanically tuned lay and lengths.
Micro Mono-Filament design.
Material:       Silver plated 99.99999% OFC Solid Core Conductors
Capacitance:       11.46pF/ft (37.5pF/m)
Velocity of Propagation:        76%
Overall Shield Coverage:        97%
Bond / Grounding Whips:       24 AWG silver-plated, stranded OFC, Micro Mono-Filament design.
Termination:
    MoonGlo® Straight or 90० low-mass 5-pin Din, RCA, or XLR connectors.
Whips and bond wire terminated with gold-plated 5mm spades.
« Last Edit: 12 Mar 2021, 02:50 am by undertow »
