***SOLD***: Liberty Audio B2B-100 Amplifier
0 Members and 1 Guest are viewing this topic. Read 810 times.
Early B.
« on: 6 Mar 2021, 12:54 pm »
***SOLD***  NOTE: I have another available for sale...
For sale is the Liberty Audio B2B-100 in very good condition. It is 100% made in the USA. This amp has upgraded binding posts and an upgraded XLR input (the one used for monoblock operation) is a high end Cardas connector.
The B2B-100 amplifier is designed by Peter Noerbaek who owns PBN Audio line of high-end speakers and electronics. The B2B-100 amplifier has seemingly effortless power despite being rated at 110wpc into 8 ohms (200wpc into 4 ohms). It has a very clean and musical signature. The amp is fully balanced, with a unique High bias/Low bias switch. Should you wish to pick up a second B2B-100 down the road, you can use them as monoblocks as they are bridgeable.
Price is $995 plus shipping within USA.
B2B-100 Technical Specifications:
•   Class A/AB Power amplifier
•   Power output into 8 Ohm = 110WPC @< 0.1% THD
        Power output into 4 Ohm = 200WPC @ <0.1 %THD
•   Mono Block Operation Power into 8 Ohm = 350W @0.1% THD*
•   Mono Block Operation Power into 4 Ohm = 600W @0.1% THD*
•   Power Consumption 200W in High Bias, 100W in Low Bias @ Idle 700W max
•   Input Impedance 75K Ohm RCA, 3K6 Ohm Balanced (1K8 Ohm per leg)
•   Dimensions 19" W x 5.75"H by 16"D
•   Weight 50 lbs.
For more information, read the reviews and the product page on Liberty's website:
- Product page: http://www.libertyaudio.com/products/b2b-100-all-mos-fet-stereo-power-amplifier
- Positive Feedback Online: https://positive-feedback.com/Issue70/liberty_audio.htm
- Soundstage:  https://www.soundstageaccess.com/index.php/equipment-reviews/520-liberty-audio-b2b-100-stereo-amplifier
« Last Edit: 15 Mar 2021, 04:59 pm by Early B. »
dflee
Re: FS: Liberty Audio B2B-100 Amplifier
« Reply #1 on: 6 Mar 2021, 05:58 pm »
If I had the cash I'd be all over this.
GLWTS
Don
Early B.
« Reply #2 on: 14 Mar 2021, 11:54 pm »
Price drop...
