SOLD: Linear Tube Audio ZOTL40 EL34 Reference Amplifier (W/ 4 SR Blue Fuses)
0 Members and 1 Guest are viewing this topic. Read 1179 times.
aniwolfe
Retail without SR Blue Fuses is $6800
Asking $3995 Shipped Fedex Insured with Paypal Coverage. SOLD!!!!!!!!!!!!!!!
Ships from South Florida
*100% Feedback on USA Mart, Audiogon and Ebay.
:::::Up for sale is the incredible EL34 based LTA ZOTL 40: The best of Tubes and Solid State combined. Designed for low and high efficiency speakers:::::
LTA amp in perfect cosmetic and operational condition. Used always at low to mid volumes, no scratches, nicks, dings or dents. I am the second owner and the unit is approximately 3 years old.
Asking price includes Tubes (low hours) Synergistic Blue Fuses throughout ($500 worth), Fed Ex ground fully insured shipping and Paypal protection.
This is an upgraded LTA ZOTL 40. Unit was sent to LTA headquarters for upgrades to Reference Status by me. 4 Caps (Mundorf) and resistors were changed out (please view photos)
Highlights
- Transformer-less design, means you hear just the tube and not the transformer noise and hum.
- Tubes run at very low heat
- Auto bias Circuitry
- Power Tube Protection Circuitry
- 2 Inputs for Direct (Bypassing Volume Pot) or Volume Pot
- Switch for Mono Block (will need a second unit) or Stereo use
- Holographic EL34 Tube power with tight tuneful Bass reproduction.
- EL34, KT77, 6CA7, 6L6 and 7581A power tube compatible.
- 46 wpc into 8 ohms, 50 wpc into 4 ohms
SPECIFICATIONS
Sensitivity: 1.2V provides full output
Output impedance: 1.6 ohms
Input impedance: 50k
100V / 120V / 240V operation: Auto-switching
Hum and noise: 94dB below full output (measured between 8Hz-60kHz +0/-0.5dB)
Gain: 23db
Power output with 4-ohm load: up to 51W, 0.5% THD
Power output with 8-ohm load: up to 46W, 0.5% THD
Frequency response (8-ohm load): 8Hz to 50kHz, +0, -.5dB
Amplifier class: Push-pull Class AB
Dimensions: 9 inches wide, 9 inches tall, 13 inches deep.
Finish: Aluminum case
Tube complement: two 12AX7s, two 12AU7s, & four EL-34s - No adjustments – tubes are auto-
biased
Tube Magic + Solid state detail
Traditional tube amps are known for their liquidity and linearity, but their “warmth” masks details and can sound thick. Solid state amplifiers give you that detail, but can be too “clinical.” Linear Tube Audio’s amplifiers give you the best of both worlds: beautiful tube tone with the clarity of solid state.
Premium components = premium sound
If you use cheap, generic parts, guess what kind of sound you’ll get? That’s why we use only premium, name-brand components. Belleson regulators. Ohno OCC wiring. Vishay Dale resistors. Mundorf caps. Typically, these are names you’ll only hear in amps that cost $10k or more.
Never buy another set of tubes
Most tube amplifiers run through tubes every 1,000-2,000 hours. That sounds like a lot until you consider that we estimate tube life for our amps to be in the 10,000-20,000 hour range. Why? Because we use ⅓ the current through the tubes, which results in lower heat and dramatically longer tube life.
« Last Edit: 11 Mar 2021, 03:53 am by aniwolfe »
Emil
No remote, huh?
Audiosaurusrex
Beautiful! Reason for selling?
aniwolfe
Wanted a change for something different. I would keep it, but I just don't want extra equipment and need the funds for something else. It really is a great amp and from what I hear the most tube sounding of all the LTA amps.
jjss49
cool -- this one has a volume pot... so it is in fact a single input integrated!
the newer ones in the broad flat case don't have that...
what power tubes are you including?
aniwolfe
2 inputs...one input for the volume pot and the other is to bypass the volume pot.
Actually that's a great question :)
Comes with Quad of El34/type, pair of 12ax7 and pair of 12au7
All the tubes bought and matched from ViVA tubes.
Does NOT COME WITH ALL THESE TUBES. Choose 1 set from list below
EL34
-Russian Tung Sol El34B (150hrs) Pictured
-Russian Mullard El34 (125hrs)
-JJ EL34L (125 hrs)
-EH 6CA7 (100hrs)
-Russian Tung Sol 7851a (150hrs)
12AX7
-Russian Mullard (100hrs)
-JJ 83s (50hrs) Pictured
-Russian Golden Lion (400hrs)
-Russian Tung Sol (125hrs)
12au7
Comes with JJ 12au7 only...my favorite modern 12au7
« Last Edit: 6 Mar 2021, 08:03 am by aniwolfe »
ricardoosusa
Great amp with volume, can be upgraded to the Z40i integrated witch is what I did. I'm very glad I did. Good luck selling it.
