~SOLD~ Canary M80 300B SET monos (black) price drop!
0 Members and 1 Guest are viewing this topic. Read 1563 times.
Sense63
~SOLD~
For sale is an excellent sounding pair of Canary M80 SET 300B monos.  These are in very good condition (8/10) with a slight mark on one of the amps that is not noticeable from more than 3 feet away.  I'll let Terry London's review below speak to the sound and construction quality of these amps.  I currently have Genelex 300B's and RCA 6SN7's installed.
Retail: $9,000 Asking: $4250 $3975
All reasonable offers will be considered, but pretty firm at this price.
Shipping to the lower 48 will be a flat $100.  Paypal friends/family preferred.
Located near Chicago in NW Indiana (46385).  Comes with original box (one box holds both amps), power cords and owner's manual.
What's So Irresistible About a Single-Ended Triode (SET) Amp? - By Terry London
The Canary Audio SET 300b M-80 is a mono-block amplifier that retails for $9,000.00/pair and puts out eight watts per channel. My demo pair came in black and was quite handsome in its appearance. As usual for Canary Audio the build quality is superlative using the finest internal components and the chassis work is on a lofty level compared to anything on the high-end market today.
These M-80 mono-blocks offered the highest level of purity of tonality/timbres, lifelike imaging both in the size of the sound-stage, along with 3D imaging with air between the different instruments, and that silky, grain-less ease that only a SET design can produce. However, strikingly compared to other 300B SET amplifiers that I have reviewed, the Canary Audio SET M-80s added powerful macro-dynamics, pressuring my large acoustic space in a way that you'd think could only be done by a 100-watt amplifier! This did not come at the expense of musicality or a natural presentation. When the recording venue had a very large space and was big on macro-dynamics/sub-sonics, the M-80 mono-blocks gave me the total experience in a powerful way. These Canary Audio mono-blocks serve up beautiful representations of acoustic music (Jazz,Classical,Vocals). However, if you want to "rock out" to hip/hop, rock, rap, dance music, electric, and big orchestra pieces, you want to have the M-80 mono-blocks driving your system.
From Canary Audio:
Single-Ended: We at Canary understand that some people are enchanted with single-ended amplifiers. Although our push-pull amplifiers have been very well received by many audio enthusiasts, we did not want those single-ended lovers think that Canary had turned its tail feathers down on them. We finally decided to build a pair of monoblock amplifiers around the 300B triode tubes in a single-ended circuit. American Craftsmanship: When building the M80 monoblock power amplifiers, we used the highest quality parts and components that we could ever find. Executed and assembled the design with the best traditions of American craftsmanship. In addition to that, the M80 is auto biasing. There is no need to ever worry about biasing the amplifiers. Listen to the M80 and experience what single-ended is meant to be.
Special Features:
Newly designed high voltage power supply.
An independent, choke filtered high voltage supply is used for each channel. .
Custom EI power transformers.
Exclusive machined Delrin 300B tube sockets with gold plated pin receptacles.
Custom made gold plated binding posts.
SPECIFICATIONS
Rated Power Output: 8 Watts RMS Input Sensitivity: 1.2 Volts for full output Input Impedance: 100,000 Ohms Frequency Response: +/- 3dB from 10 Hz to 54,000 Hz Total Harmonic Distortion: < 0.2% Signal-to-Noise Ratio: -90 dB below 1 Watt Damping Factor: 3 Power Consumption: 105 Watts (true RMS) Output Impedance: 4, 8 Ohm Tube Complement (per monoblock): 1 x 300B
2 x 6SN7
1 x 5U4G Dimensions (per monoblock): 9" W x 19" D x 8" H Net Weight (per monoblock): 38 lbs
« Last Edit: 30 Mar 2021, 01:25 am by Sense63 »
Sense63
Re: FS: Canary M80 300B SET monos (black)
« Reply #1 on: 6 Mar 2021, 03:21 am »
Price drop to $3975.
« Last Edit: 11 Mar 2021, 05:10 pm by Sense63 »
Sense63
Re: FS: Canary M80 300B SET monos (black) price drop!
« Reply #2 on: 19 Mar 2021, 09:53 pm »
Bump ^^^
