REL Subs
0 Members and 1 Guest are viewing this topic. Read 2429 times.
NoDisco
REL Subs
« on: 26 Feb 2021, 04:57 pm »
Anybody use them with Omegas? I found this to be an effective combo. I’m wondering if it’s just me.
Doody
  • Troublemaker
Re: REL Subs
« Reply #1 on: 26 Feb 2021, 06:58 pm »
Lots of folks on this board are REL fans.
I almost bought one - but ended up going with Louis' sub to match with my CAMs.
Doody
jjss49
Re: REL Subs
« Reply #2 on: 26 Feb 2021, 09:16 pm »
rel's should work great in any 2 channel application
just use their hifi, not HT models
also be sure to use the high level inputs and set up the sub(s) exactly according to the instructions
NoDisco
Re: REL Subs
« Reply #3 on: 26 Feb 2021, 09:24 pm »
Have 2 T3s for the least amount of oomph possible. Works very well.
bobski
Re: REL Subs
« Reply #4 on: 18 Apr 2021, 03:34 pm »
I have a Rel T5i with my Omega super 3XRS. My biggest problem is the speakers I think. I have a hole from 120hz to 300hz so, blending has been tricky...but I feel like I'm getting closer.
The problem is what sub is good for your space as well as matching with your speakers. But I think the small Rel is a great start.
