Industry Circles
Odyssey Audio
klaus@odyssey
Khartago input sensitivity...
0 Members and 2 Guests are viewing this topic. Read 1911 times.
MatthewT
24 Feb 2021, 04:15 am »
I'm thinking of ordering a Luminous passive pre and need the input sensitivity to complete the order. The impedence is listed, but not the sensitivity.
ETA: 1 volt per Klaus.
Last Edit: 25 Feb 2021, 12:49 am by MatthewT
DeeCee
Re: Khartago input sensitivity...
24 Feb 2021, 05:27 am »
I thought it was 1V, but I’m not sure. Your best bet is to call Klaus. He may be able to optimize it for you!
HTH,
DeeCee
geerock
Reply #2 on:
24 Feb 2021, 03:17 pm »
1v is correct.
MatthewT
Reply #3 on:
25 Feb 2021, 12:50 am »
Quote from: geerock on 24 Feb 2021, 03:17 pm
1v is correct.
jjss49
Reply #4 on:
26 Feb 2021, 09:18 pm »
i have found odyssey amps to be on the more sensitive side when coupled with preamps - moreso than most other well known higher end power amps be they tube or solid state
klaus@odyssey
Facilitator
Reply #5 on:
27 Feb 2021, 12:04 am »
No, they don't ...personally, I have yet to find a mismatch with a tube pre....the amps just love tubes, and while there are differences in noise etc. stemming from the tube units, yes, you can't argue with the performance results.........
geerock
Reply #6 on:
27 Feb 2021, 04:13 pm »
I've used my Kismet in Stratos monos with 2 tubed preamps (the latest being a Don Sachs) and the results are excellent, smooth music.
Industry Circles
Odyssey Audio
klaus@odyssey
