How to treat an 85 " TV
0 Members and 1 Guest are viewing this topic. Read 3825 times.
Longandstraight
« on: 17 Feb 2021, 05:39 pm »
I have an 85" Sony 900 H in between my speakers. I want to build something to cover it for serious listening sessions. I know the sound is going behind it and making a mess also. I was thinking 12x12 panels glued together with maybe a sheet for a protective liner. I could wrap the tv and extend the edges  the 6 inches or so the Tv hangs of the wall.
Sound silly or like it may be an inexpensive fix?.
Thanks for the input
TomS
Re: How to treat an 85 " TV
« Reply #1 on: 17 Feb 2021, 05:47 pm »
I put these 2 RPG panels up in front of my 65", just resting on top of the cabinet. They are very effective - light, stable, and easy to remove and put back.
JTF
« Reply #2 on: 17 Feb 2021, 06:09 pm »
I did the same thing, I built a panel that sits in front of the tv.
WGH
« Reply #3 on: 17 Feb 2021, 09:00 pm »
I use a colorful Mexican blanket
Big Red Machine
« Reply #4 on: 17 Feb 2021, 09:06 pm »
But Wayne, the stripes are 90 degrees off! :lol:
Big Red Machine
« Reply #5 on: 17 Feb 2021, 09:13 pm »
in my system, you will see barn door rollers that I attached Real Traps panels to slide in or slide out. You could ceiling mount this.
Or make a custom passive like JTF did for way less engineering. :duh:
glynnw
  • I have tin ears.
« Reply #6 on: 17 Feb 2021, 09:22 pm »
I made a panel out of the acoustic stuff I have on the walls.  But frankly, I never use it.  I just do not hear many of the things that fellow audiphiles say affect the sound.  Guess I just am not the subtle type.
veloceleste
« Reply #7 on: 19 Feb 2021, 04:02 pm »
« Last Edit: 21 Aug 2023, 05:56 pm by veloceleste »
dpatters
« Reply #8 on: 19 Feb 2021, 06:56 pm »
I used to hang PI Audio Group diffusers over the tv. Was a pain to be quite honest and I didn’t feel the improvement in sound was worth it. Life’s full of compromises.
Don P
Longandstraight
« Reply #9 on: 15 Mar 2021, 03:59 am »
Thanks for the replies. I reached out to a few pros and they basically said to try to pull the speakers out in front of the display as far as possible and not worry. I am up almost 3 ft from the front of the speaker to the display  I will try a comforter first. But maybe not such I big deal.
jk@home
« Reply #10 on: 15 Mar 2021, 10:29 am »
We had power blinds installed in our master bedroom for the two large windows in there. Expensive as heck, but man are they so cool, just push a button to open or close them. There is probably some blind material out there you could use that isn't reflective, you could hang it over the tv and with a push of a remote, instant room treatment.
artur9
« Reply #11 on: 15 Mar 2021, 04:44 pm »
The biggest effect I think is reducing/eliminating soundstaging.  Some say soundstaging is illusory anyway (I disagree).  Or precision imaging.
For now, I have separate systems.  The thing that really bugs me is not having dialog come from the TV so I used 2 centers.  That is also an atrocity according to some :-D
tamcongdinh
« Reply #12 on: 20 Apr 2021, 06:47 am »
It's nice idea, I do the same way at my home
Digi-G
« Reply #13 on: 20 Apr 2021, 01:55 pm »
I must be one of those people that can't hear the issue.  OR, I have my TV back far enough (8" from the wall) and speakers into the room far enough  (36"+) that it's not an issue.
WGH
« Reply #14 on: 20 Apr 2021, 04:04 pm »
Here is an idea I saw on Houzz.com
Not my house
mick wolfe
« Reply #15 on: 20 Apr 2021, 05:38 pm »
This is my solution. But as someone has already mentioned, not sure I hear an immense difference with or without  :scratch:
I like the solution Wayne found in Houzz.com, but that's way above my pay grade :nono:
emailtim
« Reply #16 on: 26 May 2021, 07:36 am »
I like the barn door roller idea.  Could easily swap out absorption or diffusion panels.
Looks like there are a few DIY hardware ideas.
https://www.youtube.com/watch?v=PiORuP3nlM4
