Bdp-2/3
0 Members and 1 Guest are viewing this topic. Read 708 times.
drummermitchell
Bdp-2/3
« on: 12 Feb 2021, 08:47 pm »
As I leave all components on 24/7 except amps,
As far as the battery in the bdp-2 ,I’m wondering if it should be changed.
Probably been 5 yrs or more.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bdp-2/3
« Reply #1 on: 12 Feb 2021, 09:18 pm »
Hi Don
Only if you get startup issues.
james
drummermitchell
Re: Bdp-2/3
« Reply #2 on: 13 Feb 2021, 01:28 am »
Thx,all’s good,
Curious are the bdp-2s still upgradeable to the 3s for $1.49 .......................
Seriously is Bryston still offering this,perhaps not for $1.49
But around the 1500.00 mark,forgot the upgrade price
Thx
R. Daneel
Re: Bdp-2/3
« Reply #3 on: 13 Feb 2021, 11:26 am »
As in one dollar and fortynine cents? Are you serious?
As far as I know, the upgrade is 1500 dollars but it depends whether the BDP-2 to be upgraded already has a built-in IAD board or not which is 500 dollars alone.
Re: Bdp-2/3
« Reply #4 on: 13 Feb 2021, 11:49 am »
Hi Folks,
Yes the BDP-2 can be upgraded to the BDP-3 but the BDP-1 can not.
james
